Yucca-Man
NAXJA Member # 683
- Castle Rock, CO
Yeah....right. http://denver.craigslist.org/car/690384858.html
Methinks someone needs to correct a speedometer gear...
Yucca-Man said:Yeah....right. http://denver.craigslist.org/car/690384858.html
I heard some where that the renix is better on gas miliage anyways. but I could be mixing up my facts.Stang5lgt said:My 89 XJ got 20mpg once in awhile on 33s. Usually it got 17-18 mpg range. It is pulling 17 mpgs this last tank on 35s and 5.5 lift. 5 speeds makes a big difference. Plus my XJ is 2 door with no options so it pretty light weight.
You should be ok with lift and tires. I lost couple mpgs. I even squeezed 21mpg couple times with 33s and stock 3.08s Never got to use OD . 4 gear everywhere.DutchVDub said:My 92 Laredo gets better mileage than my 99 XJ did. I only averaged 18-19 mpg in my 99 and I have been averaging 21-22 in my 92. Both are/were fully equipped w/ pwr windows, locks, and a/c. The only difference is my 92 is a 5spd. I'm hoping the lift/tires won't hurt my 92 as much as it did my 99, the 99 dropped down to like 12-14mpg after the 32's were installed. Main thing that killed it was the lack of being able to maintain overdrive on the highway. While I probably won't be able to use 5th all that much I think 4th on the manual will be a more highway mileage friendly gear than 3rd in the auto.
Find a diesel XJ.Yucca-Man said:Interesting discussion that's evolved after the original post. Also interesting that nobody mentioned the big-azz platform up top that should help eat another 1-2mpg...that's a boatload of aerodynamic drag!
I've seen some pretty sketchy "calculations" for gas mileage on this site before, and know that even a good calculation will be wrong if the speedo gear is wrong - I still feel this one had to have been one or both of those problems.
Whatever...I'm not in the market for anything that gets less than 30mpg anyway. :shrug:
Jim www.yuccaman.com
