2 Door Rear Windows
Does anyone know if the 2 Door Rear windows with a the vents will fit a 97+ 2 door?
Is there anything special I would need to do to remove the windows with the Vents?
Thanks.
Yep, they'll fit. The vent windows are MUCH more difficult to get out. They have a metal frame inside the rubber trim/gasket.
Bring soapy water in a spray bottle, and 2-3 flat blade screwdrivers. Youll need to remove all plastic and metal interior trim panels around the windows. Start at the back corners. Work the gasket inside lip so that you're tucking it up, over and out to the outside of the pinch seam of the window opening. Use the other two screwdrivers as wedges to keep the lip you've tucked from popping back inside. Once you get 6"-12" started it gets easier and you can use the screwdriver and run it along the gasket lip tucking it as you pull. This is where the soapy water is important....to keep the gasket lip from tearing.
Good luck!
