fosforito_one
- Orem, UT
This is a list of some of the stuff I have done to it. To see the full ad use this link http://www.ksl.com/index.php?sid=733005&nid=443&tab=myads/view&ad=4277970
- Brand new Engine at 150,000 miles
- Magna Flow exhaust
- New exhaust header
- New brown dog motor mounts
- 3" Rubicon express lift
- Slip yoke eliminator with custom drive shaft
- Currie ford 9" rear axle (10 degree shims under rear axle)
- ARB airlocker in the rearend with wired in ARB compressor
- New aluminum radiator
- Tranny oil cooler
- HD fan clutch
- 33 10.50 BFG AT's on 15" 8" wide" black painted pro-comp wheels
- 4.10 Gears in the differentials (15/18 mpg)
- Extended Stainless steel braided brake lines
- All new hoses done with engine swap
- K&N performance air intake
- High clearance TJ fender flares
The jeep is located in Orem Utah 84057. If interested call or text me at (Joe 801-783-8849)
- Tranny oil cooler
- HD fan clutch
