AJ_learns_XJs
- San Diego County
Selling my 1987 Renix Jeep Cherokee XJ. I have had it for 6 years. Has 225,000 miles. Time to sell it and get something more family friendly (read 4 doors).
Good stuff
Synergy MFG heavy duty steering with brand new Bilstein Steering stabilizer:
https://www.synergymfg.com/synergy-jeep-tjlj-xj-zj-mj-heavy-duty-steering-kit.html?category_id=4883
JCR unibody tie ins:
https://www.jcroffroad.com/product/XJUNF-PC.html
Factory Steering bolt sleeves were drilled out and DOM sleeves welded in to ensure unibody would not crush.
Core 4x4 tier 4 double sheer track bar with Johnny Joints on both ends and track bar frame mount:
https://www.core4x4.com/product/dou...track-bar-w-bracket-t4-comanche-mj-1986-1992/
Rough Country lower control arms and Rough Country 3in coil springs:
https://www.roughcountry.com/jeep-s...MIgdvp_PDx5gIVFq5kCh3z1wRGEAQYAyABEgKILPD_BwE
Old Man Emu CS033rb Leaf springs:
https://www.4wheelparts.com/p/arb-leaf-spring-cs033rb/_/R-BHWQ-CS033RB
JK red body shocks all around with bar pin eliminators
D and C 2 door XJ kit plus installations:
https://dandcextreme.com/product/jeep-cherokee-xj-roll-cage-kit-2-door/
rebuild Dana 30 axle at Pro Gear with cable CAD, 4.10 gears and Eaton Detroit True-Trac locker and Poison Spider diff cover:
https://www.summitracing.com/parts/...MIyd3N4fHx5gIVBsJkCh2ibgoCEAQYASABEgJSJ_D_BwE
1995 XJ Dana 35 with factory LSD, Alloy USA chromoly shafts and B & M Diff cover with load bolts to help bearing cap deflection (diff cover not installed):
https://www.holley.com/products/discontinued_product/parts/11311FM
https://www.4wd.com/p/alloy-usa-dana-35-chromoly-rear-axle-kit-12200/_/R-BKWL-12200?ppcfon=1&gp=1&ef_id=EAIaIQobChMIhfDIz_Px5gIVB9VkCh31rggBEAQYBCABEgLWR_D_BwE:G:s&s_kwcid=AL!7836!3!389350609662!!!u!293946777986!&s_kwcid=AL!{7836}!{3}!389350609662!!!u!293946777986!&ecmp=s:google&utm_source=google&utm_medium=cpc&utm_campaign=shopping&emlprox=out&ppcfon=1&gp=1&gclid=EAIaIQobChMIhfDIz_Px5gIVB9VkCh31rggBEAQYBCABEgLWR_D_BwE
Stinky Fab Driver train kit. Motor mounts, block mounts and trans mount:
Renix Engine Monitor computer by NickInTime:
New HD OEM radiator
31x10.5 Hankook Dyna Pro MT on Cragar Soft 8 15x8 wheel with matching spare:
Factory spare tire swing out
Custom rock sliders (need to be reinstalled)
Bad:
33 years old so typical Renix stuff. Door locks don’t like to work with remote and windows roll up slow.
Rear Main seal leaks oil about 1 quart a oil change
Driver seat needs to be reupholstered
Engine has 225,xxx and runs fine on flats but is getting warm when going up hills (i.e. new radiator which helped but didn’t fix the problem).
Asking $4,000 for entire car or may part out starting with drive train first.
Will Smog before sale.
Can't post pictures so here is the link from Craigslist:
https://sandiego.craigslist.org/csd/pts/d/san-diego-jeep-xj-cherokee/7051540341.html
Good stuff
New HD OEM radiator
Bad:
