- Near Rochester NY
I want to install tinted glass in the rear doors and the rear quarters. I started with the rear doors but can't seem to get the old glass out.
I have the FSM and have found all the hardware referenced in the FSM, except a rivet, which I can't find. I searched here and found one reference to a rivet from the outside of the car, under the outside metal trim strip. Can somebody confirm if this is where the rivet is located? If so, how in hell do I get this bottom trim strip off without bendint it all up?
I also read that I could replace the fixed pane of glass from the bottom, without removing the rear window track and frame assembly. I this true?
Since I am replacing the movable rear glass, does this mean I have to remove the fixed window and frame first?
Any advice would be greatly appreciated. TIA.
