redneckboarder
- cumberland RI
i got a bunch of stuff in my way. come buy it
stock tj rubi driveshaft $50, rear xj shaft $50 good shape
stock YJ radiator $50 and a rad for a v-8 yj...im pretty sure its a TJ rad $75
stock YJ steering column, tilt and the whole shaft to the box $40
Yj steering box, worked no leaks when pulled $100
stock YJ fenders/flares, no rust, black
d30/d35 and stock yj steering and leafs. rear has no noises or issues that i know of 4.10 gears front gear condition is unknown it has no shafts and the jeep is 2wd $100 for both axles and $50 for the leafs
misc gauges assorted brands. one is fuel, volts, temp, oil pressure. YJ bezel that holds them $30 for the lot and im not splitting it up. Ill take details pics if you are interested
roof rack with locks and drip rail mounts. its a yakima and thule i have the keys
B&M ratchet shifter everything included. not perfect but works fine $20
PSC steering pump for 4.0 i beleive it will only work for 90-95. I'm going to research further for a definite answer but it came out of a YJ. 5.5" serp pulley, no resivoir or lines $150
items are located in cumberland RI delivery may be a possibility. call/text jon at 603 348 6116
