YJ flares
XtremeJ
East Otis, MA
I know you can use TJ flares on an XJ but can you also use YJ? Any difference because I see the YJs are cheaper.
Thanks, Earl
Phil Weeks said:
I believe CheapXJ is running YJ flares. If I remember right, they are smaller than the TJs.
the YJ front flares are larger in opening than the TJ flares, the rear ones are tiny (fine for anything up to 33" though)
they don't offer much more coverage than stock XJ flares (maybe an inch more)
I had to put the rear one up that high so the tires didn't rip it off, the front one is in the same place as it was when I had the 33's
