Yet another ZJ question
sullju
East Texas
I'm trying to remove the rear track bar on the ZJ and I've hit a wall. The nut is, I'm assuming, welded to the control arm mount. The bolt is torx and it's now getting stipped out. I've allready used a whole can of penetrating oil and it still won't move. Anyone have any ideas? It's a T55 torx and I can find any bolt extracter to fit.
Justin
if you can do it with the weight of the jeep on the tires, it will take the load off of the track bar. otherwise a good strong impact wrench should do it. the nut is welded to the axle housing but not on the frame.
Thanks for the tip. I realized it was welded after I took the UCA off. Oh well, 3 beers and alot of swearing later I finally got it off.
