XJ Steering Brace, Speedo Gears, Seat Sliders, U-Bolt Yoke, Warn Winch Remote
RCman
USA
This is the outer steering box brace and frame sleeves only. Very light surface rust.
Asking $30 shipped or $15 if you come to an event and I can hand it to you.
http://www.c-rok4x4.com/
Brand New 34 tooth and a Used 35 tooth. I believe the part numbers are 52067634 and 52067635.
Genuine Mopar units, not cheap knockoffs.
Asking $12 shipped or $5 if you come to an event and I can hand them to you.
New in box, some light surface rust. Upgrade from that strap style to the stronger U-Bolt style.
Includes a used nut (that I would personally only use for setup purposes, always use a new nut when installing a yoke).
Asking $35 shipped or $20 if you come to an event and I can hand it to you.
http://www.omix-ada.com/dana-30-u-bolt-style-pinion-yoke-72-98-jeep-cj-models.html
Beard Sliding Seat Adjusters. These probably work with many others like PRP and Race Trim. Needs connecting cable (steel fishing line).
Warn winch remote from M8000. Contacts meter fine but since I have no way to actually verify it; free with anything above otherwise $5.
