99NCXJ
- Belmont, NC
Here is a consolidated list of all my post. All prices are OBO and any trades considered.
XJ Parts-
radiator suport 30.00
factory header pannel for xj. no grill, just the header pannel 40.00
in tank fuel pump 25.00
steering gear box 50.00
Dana HP 30 (non vac. disco) housing only 50.00
D30 Knuckles 40.00
D30 carrier, 3.55 ring and pinion gears 40.00
Chry. 8.25 housing 50.00
YJ Parts-
tail gate a little bent up. Not bad… 15.00
4.2L water pump 25.00
ZJ Parts-
stock zj rear coils 30.00/pair(from V8)
glove box and door 15.00
washer fluid tank. 5.00
steering column with steering wheel and air bag 50.00
steering shaft 10.00
over head console 20.00
headlights 15.00
dash controlls 15.00
radiator support (5.2L) with hood latch 25.00
gas pedal assy. 10.00
brake pedal assy. 10.00
transfercase shifter assy. 10.00
polly gas tank (was going to be used as fuel cell) 50.00
air box…5.2L 10.00
front door glass. Driver and pass. Side. 10.00 each.
MJ Parts-
Dana 30, vac disco parts...rotors, vac assy, housing, calipers, ect.
stock drag link 15.00
stock tie rod 10.00
brake booster/m.c. 25.00
prop. valve (under mc) 15.00
prop. valve (above rear axle) 15.00
lots of dash parts, guages, pedals, bench seat,
AW4 tranny 21 spline 150.00
NP231 21 spline 150.00
Comanche long bed (box only) no major flaws 200.00
comache tail gate...not too bad...not perfect... 40.00
Drop in bedliner for long bed comanche 100.00
set of stock mj wheels with tires 100.00
MJ fuel tank, no sender. 10.00
Misc. Parts-
New set of white steel wheels (4) 5 on 4.5 3.75 bs. 150.00
1943 military jerry can. green with USMC on front. 100.00
BA10 tranny, needs bellhousing 40.00
lower coil buckets for radius arms 10.00
(2) Dana 44 diff covers 10.00 each.
TJ stock front springs 25.00
15 by 7 steel wheel. 5 on 5.5 (think it is a geo tracker wheel) 10.00
1972 Honda QA50 dirtbike
collector bike
is in parts in a box. frame has been painted. 150.00
XJ Parts-
D30 Knuckles 40.00
YJ Parts-
ZJ Parts-
headlights 15.00
air box…5.2L 10.00
MJ Parts-
stock tie rod 10.00
Misc. Parts-
collector bike
