GlueNTape
- Tualatin, OR
Okay here is the summary. With the rain we had, It took me forever to get this done. Floor turned out good. It does what was expected. I was surprised at the sound levels. Without carpet, while driving on the road and highway the sound levels varied between 77 and 83 dB. This was with a directional meter held in the passenger seat and pointed at the floor. After the layers of Dyna-products and the Vinyl floor, the measurements dropped to 68~74 dB. Here is a link to info on Decibels They are not like measuring inches. They are logarithmic. Much like the way Earthquakes are measured.
Anyhoot on the the install pics..
I started with
36 sq feet of DynaMat and DynaLiner and a replacement vinyl floor from Auto Custom carpets.
I had a lot of DynaMat and Liner left. Enough to do my doors. Although, I did not do the cargo area, yet.
First thing I did was clean all the rust spots up off the floor. There we a couple small spots and a few spots where there was a little bubbling below the paint, after scraping off the bubble there was rust deposits. So, I wirewheeled and cleaned all the spots. Primered and Painted with a few coats of Rustoleam.
Then came the DynaMat install. Its some cool stuff. I was surprised at how easy it is to apply. I used the Dyna-roller that they sell. I didn't Make cut outs and templates like they suggest. I would roll out a big square and then fill around it with smaller pieces.
Started on the passenger side- cutting and rolling. You can see the rubber shield/insulation hanging down. I left it and just worked around and under it. It was easy enough to push around.
One of the hardest things was keeping the work area clean. My jeep is a dusty beast. Even with the carpet removed I kept a damp rag handy to constantly wipe up dust before I laid down the Dynamat.
A little more progress on the passenger side. I didn't cover the seat mount initially, but did go back and cover it.
Here is a look at the drivers side. It was pretty straight forward. Just cut and fit, repeat..
I started with
