XJ Fender Flares
They are in stock as of this morning. Just ordered a set....
Those are the best "looking" flares I have seen to date and the fact they seem to offer the most clearance is a bonus. I could probably run 33's on my 3" lift with those. I do question them popping off if I run into a tree though...
3" lift and 33" tires is what I will be running with these flairs i got for christmas.
Someone tell them their domain name expired 12/28/2014 and needs to be renewed. :doh:
I am trying to keep my CG low on my next build, what is the largest tire I can fit using these flares with 1-1/2"- 2" lift ?
Thanks for any answers in advance!
I've got 3.5 and a set of XJ-Max flares. I'm currently running 32's and they look a little small with all the room I've got. Next set will be 33's for sure.
Don't think I'll need to be going any higher. VERY happy with where I'm at, thanks in no small part to these flares.
You can do 35s, but your up travel will of course be limited. When stuffed, 35 fills them up just right. I have these flares, 35s, and about 5-5.5 of lift. My front tires are about 10 inches away from the flare at ride height, and the rear is about 7 inches.
room for 37s?
Hard to say. I am looking through my pics and vids since I had these on and am not finding anything where it is flexed out and I have a good shot of it straight from the side. My 35s fill them up, and do not hit the sides. I THINK a 37 would make it in there, and would rub the sides a bit before getting to the top. You might want to email NOTCH about it and see if they have customers on 37s and how it is working out. If I flex it out any time soon, I'll see about getting some good straight side shots for better reference.
All those test are what we mallcrawlers do to satisfy spending the money.
The stair surfing is impressive for durability tho. Try a 300 lb intern next time.
How much fender do you need to cut front and rear?
Mine had bushwackers on beforehand. Here is where I cut:
