Thanks Gordon. It was nice meeting you and your family too. I look forward to meeting up soon.It was good meeting you today bud. My daughter said your jeep was an army jeep. It is coming along quite well.
Sent from my SM-N910P using Tapatalk
Finally got the roll cage finished up![]()
Loving the Model 32 bender. It's getting easier and easier to use.
Sent from my SM-N920P using Tapatalk
Thank you. It's taking forever to get done...My wife keeps me pretty busy on the weekends.Really nice work on the cage! Really have enjoyed reading through your build. You've come a long way and it's a looking XJ!
The under the hood components consist of a 12 circuit fuse panel (driver's side fireawall), a cheap amplier install kit, 4 Viair relays (passenger side firewall, lots of wire (obviously), spade connectors, and those other connectors (I dont know what they're called but it's kinda like a ring connector but open on the end so you can slide it under a loose screw without having to take the screw all tbe way out).
The panel and amp indstall kit came ftom Amazon. All I used from the install kit was the heavy #4 wire and fuse to run from the battery to the fuse panel. The kit was cheaper than buying the wire/fuse on their own.
The Viair relays came from Summit Racing.
I bought some ratcheting crimpers (Amazon) that really spread up the process and made really nice crimps. Usually my crimps don't hold, but the crimps with this crimper are solid. I can get you the name and model if you want it.
Post up a pic or 2.I understand. My honey do list seems to never end. My XJ only crawls on the sand here around Virginia Beach or the Outer Banks. It's been a fun build.
They were some cheapies off of Amazon. I couldnt paste the link, but here's the description. They're $43 right now and they do fit pretty well. Im contemplating making some out of OD green cordura because I have like 9 yards left after the roll bar covers.Cool build so far.
What brand are those seat covers? They look like they fit decent on the stock seats. I haven't been able to find any good fitting covers that are decent priced.
