So now to deal with the different axle ratios. I went to 4wheelparts and got a quote for gears, an E Locker, and 30 spline G2 axles. Basically a Super 30.
They talked me into a G2 TJ Dana 44 because it was only like $500 more for a complete assembly up to the C's. I paid for it, but it was back ordered forever and they couldn't give me a delivery date.
Meanwhile I do more digging in the forums and research the difference between the TJ 44 and the XJ HP30. The tubes are the same wall thickness so no advantage there, in fact I would argue that my trussed D30 was more bend resistant than the D44.
The D44 is a low pinion, my D30 is high pinion. This relates to a steeper driveshaft angle and possibly a need to lengthen my shaft.
As for the ring and pinion, many people say the reversed cut D30 ring and pinion is as strong, or almost as strong as the D44 (low pinion). Not sure.
Axle shafts, both the D44 and a Super 30 use 30 spline shafts...same same. The drawback here is I can't get trail spares from the junkyard.
To do the D44 I would have to make a truss and create a mounting point for my upper link.
I considered all of this and decided to cancel the order for the D44 and build the D30.
