WTB XJ CPS Bolts
88 xj 4.0 AT 4wd
part number 52088116AB Engine Speed sensor mounting bolt
list price 7.35
No longer serviced by DCX... good luck on finding one.
I have a spare CPS with a bolt I will measure tonight.
finally got around to it.
what you need is a 20mm long m7 bolt with the top 10mm as unthreaded 8mm shank
warning crude ASCII art below. You may be able to get away with a M7x20mm common hex bolt from the local home despot. if its a bit loose a sleeve to shim it out to 8mm may be needed.
That shoulder is pretty critical - it's what locates the CPS. Sounds like I've got another project to design... I may still have measurements on those bolts drawn up - but I've got a loose ONE I can measure if not.
If you get the right thread, you can get away with using the sleeve idea to register the CPS holes, but find some way to make sure the CPS itself is retained when you bolt it down. You don't want it to "swim" or "fly" when you're not looking...
5-90
