shelbyluvv
- 29 Palms, CA
I need some stuff to get the MJ closer to completion. I need the following, as cheap as possible. I am on a really tight budget right now.
Floor shifter (auto) and cable to the trans. I will need all the mounting hardware too.
Stock upper control arm with good bushings. I would like the bolts too if possible but, not a deal breaker.
High beam switch on the bottom of the column for a HO ERA XJ or MJ (91-96)
And lastly, a HVAC suitcase under the dash. It can be either AC or NON AC.
The closer to 29 Palms the better. If you are parting a rig I am plenty capable of pulling the stuff myself. I know the these parts are a PIA to pull.
Let me know what you have.
