WTB: Oil Pressure Gauge Sending Unit Harness
Scorpion8
Juneau, AK
Who's parting out a 98-ish XJ with 4.0? I need the harness plug that plugs into the oil pressure gauge sending unit (above the stock oil filter) and as much of the wire length as you can pull out of the wiring harness that belongs to it. Needs to be in good condition. My harness connector is bad, and doesn't make good contact with the two pins of the oil pressure sending unit.
Thanks!
Anybody going to a junkyard that can clip a two-prong quick-connector off a 98+/- XJ, please? A small padded envelope to Alaska should only be a few dollars.
