WTB: 96-99 Dana 30HP
1989TwoDoor
I am looking for an 96-99 XJ Front Dana 30HP, cheap. 3.55 gears prefered. Central Indiana :repair: Thanks
I have all the parts to put one together. If you want to make the drive its yours. I have axle shafts, housing (might need new ball joints but i dont remember) I have the R&P and all shims. If you want to make the drive and can assemble it you can have it. It's located in Gurnee Illinois 60031 one if you want to map it out.
Never mind. I found a good one at the local Pick-A-Part. I found an XJ that seemed really rare. It was a 96 two door with a 5 speed 4 cylinder, so the dana 30 HP (big joints) I pulled has 4.10 gears.:yelclap:The rear was an 8.25 with 4.10's if anyone in Central Indiana is looking for a good rear axle.:wave: I already have a 44 rear or I would have grabbed it. :patriot:
