WJ steering wheel retrofit
Ben824
Woodstock, GA
Has anyone retrofitted a WJ steering wheel into a 97-01 XJ and made the radio controls work? My fiancé's WJ has them and I love using them and thought how I liked the look of the wheel as well. Just thought I would ask because googling and searching here didn't turn up much.
So far my research has turned up that they indeed bolt right up, splines are identical, 99-01 WJ airbags perfectly match XJ specs and will work the same as an XJ airbag, I believe the same 99-01 WJ cruise controls will work, but I haven't found anyone that has made the radio controls work. I found a single thread on the Jeepin.com forum board where they talked hypotheticals and discussed whether or not using a 99-01 WJ clock spring would work. Also unsure if the BCM would need to be used to accept the inputs from the radio control switches or if for an aftermarket radio, using an aftermarket radio to OEM steering wheel control adapter module can simply be tapped onto the exiting pigtails off the clock spring.
So those are my unanswered questions and I don't know enough about all those circuits to test it all out. But if someone knew the answers then I will be the Guinea pig to try it all out.
Hey Ben824, I know this thread is long in the tooth, but did you ever try to connect the audio controls up with a PAC? I was thinking of doing this myself on my XJ. Greetings from OZ.
