seanyb505
- Simpsonville, SC
Background - Aging 97 XJ with super sloppy steering. Im shooting for a factory performance version type XJ with more modern systems and more performance. Think late nineties R/T, along the lines of a Dakota R/T. Or current SRT vehicles.
Steering - My 13 year old steering that I dont think has been changed since 1984 needs repair. Its just old. I know the offroad guys use WJ for numerous reasons, however I encounter none of them other than sloppy steering. I know just repairing my stuff will tighten things up; I would like it better if possible. The cross over stuff looks tighter than inverted y and more responsive to steering input.
Brakes - Ive heard that if you can lock up your brakes you dont need a brake upgrade. I think with the WJ dual piston calipers there may be more control near the limit. Further more, I think there are plenty of vehicles today that receive brake upgrades as part of a performance upgrade. AMG and M both come to mind. Im sure the normal product lines could lock up the tires just fine without ABS. Which brings me to my next question - Would I only see benefits from WJ brakes if I installed ABS? I know that would take a lot, but my SE has been plug and play with a lot of options it didnt come with, so I know there would be a way to retrofit it. Rear disks are in the works also.
Do you think for a Cherokee R/T or SRT (however you want to look at it) WJ stuff would be overkill and useless, or could I benefit from it all? It's going under the knife this summer, Im not positive on whether this stuff will be included.
