Chris... the real issue with washers is that the wheel doesn't tighten right at the studs. It tightens around the edge just outside the bolt circle. The issue is that while the wheel can easily tighten against the rotor, there is nothing behind the rotor (a gap) where the wheel hits it.
Im not going to argue. I did the measurements and I assure you I am correct, however, when I do the swap on the U-joint axle in a couple of weeks I will take more detailed photos to prove my point. A simple way to prove it is to take before and after measurements... go from the inner c surface (right next to where the axle tube is pressed in) and measure the distance between that and the center of the u-joint. If it is the same before and after, then its fine, nothing moved. If it were a 1/4" in further (which would never work due to the shaft hitting the cross pin, again proving I am correct) then you would know the spacer is needed. The center of the u-joint needs to line up with the axis of the ball joints, we all are assuming they do line up from the factory. So... if you have to pull the shaft out of the carrier by 1/4" then it would no longer line up with that axis. In theory, if the spacer was really needed, you would have to run it, because otherwise the end of the shaft would hit the cross pin which wouldn't allow the unit bearing to be bolted in all of the way.
So I say whatever. You guys don't know me from adam, all you know is that I pay to advertise on here and have a blue name (my other screen name). Most of you have not seen my work, and those who have trust me and my judgement.
I will take pictures of the measurements and post them up when I do the other one.
As for the RCV having in and out movement, nope. They only turn, no lateral movement whatsoever, so if they aren't centered on the ball joint axis, they would bind the same as a u-joint. They didn't bind at all in this application. I could easily rotate the knuckle around and still turn the shaft by hand which clearly would not be possible if it were an issue.
Any updates?
Explosions, affirmations, new builds?
x2My setup is still problem free and stopping my Jeep like nobody's biz-ness........
My setup: WJ knuckles w/ JKS weld on spacer, 1999.5+ unitbearing (PN 513158 or TIMKEN PN HA597449), redrilled WJ rotors, Akebono calipers ground slightly to clear 15" steelies.
I think I'll use the JKS spacers & 2000+ bearings + drilled WJ rotors.
not trying to argue but... the red arrows are offsets and the 2000 xj is1.907,2004 wj is 2.118,and the 1998 and older xj is 2.133. so with those numbers the 98 xjand older hubs match the wj hubs the closest. only .015 inch difference . the 2000 xj hub is .211 inch shorter/different(which i can see why the spacer is needed then). so what is the advantage to running 2000 xj hubs with a spacer? vs 1998-older hubs?
so i've read all the pages and am curious if anybody has the dimensions for all the hubs?(2000xj,1998xj,2004wj) red and yellow arrows. if im following everything correctly the yellow arrows are important for u-joint center on the ball joint axis and the red is important for the rotor to caliper alignment. it's hard for me to get out much with all 3 kids so when i am able to get out i would rather be anywhere but the parts store waiting. i'm also sure it would help set in stone for others if the spacers are needed for just the 2000xj hubs or for both/all the 2000 and 1998-older hubs. i'm trying to gather all the parts needed for this swap and was also wondering if the tre tapers are the same as the stock xj dana 30 knuckles(i need to get ride of my rr setup fast and would like to only pay/buy once) all help/knowledge is appreciated, thank you
So why hasn't the original poster come back with the information that he promised?
Good question - though I think it would be unfair to assume guilt on the basis of incommunication, regardless of what our wives & girlfriends may think...
..... I believe they would be found on non quadra 4x4 systems. Like on the 231/242 transfer case WJs... much like the ZJ.
