Are the front diffs in the WJs hi or low pinion? I have a bent front housing and was thinking of using the WJ knuckles. Then the thought occurred to me, why not just pick up a WJ housing??
Pinion location was my only concern since I made my own DIY D44 hub conversion, and have warn axles. I was just going to transplant the gears, locker, axles and hubs/spindles. And rebuild the CA mounts like I currently have.
When you hit a hole/ditch hard enough to make the rear wheels come 4 feet off the ground, it tends to bend things a little.:shocked:
