WJ booster + master cylinder $75 obo
kastein
in decent shape, some surface rust on the booster where the two halves of the shell are crimped together. Comes with as much of the hardlines as I could cut loose, all the specialty flare nuts, the reservoir and cap, etc.
This is an upgrade for 94 and earlier, 95 and later it's really not much of an improvement, if at all.
I'm honestly not sure - I forget, what axles/brakes are you running? I can bring it to nacfest for you either way.
i have that booster on my MJ with the disc 8.8 and it locks up my 35's and has a nice firm pedal. I also have the ZJ disc brake proportioning valve
