Figured it out, brake light wire. Clip that held the wire to the body near the brake light wore through and grounded it out. Burnt the wiring all the way to the switch at least. Rhd and lhd body wiring similar?
Wiring is similar, the wht/tan is the load side of the brake switch. The wire should only be melted from the ground point and switch, and the B+ side of the brake switch that goes directly back to the PDC.
