Will my drive shaft fit?
xjcrawlr
phoenix AZ
I have a D35 that I'm throwing away and I'm replacing it with an 8.25 (29 spline) and my question is will my current drive shaft just bolt right to it?
I seem to remember something about the yokes being shorter/longer?
I DID.....inconclusive
My drive shaft is not stock, its a YJ slip yoke with a slightly extended shaft. SOOO if the 8.25 pinion is longer than it might not fit, but if its a little shorter than it will.
If I could have found the answer I was looking for by SEARCHing, I wouldn't have asked.
just making sure :D
i believe an 8.25 has a longer pinion than a 35
yep. the 8.25 pinion is longer. lift your jeep another 2" and problem solved :)
