W WB9YZU NAXJA Forum User Location Madison, WI Dec 19, 2016 #2 Does the "Flash" function work? High Beams work fine huh? Check fuses 4,5 on the junction block. It seems to me that the only things between the main fuse 7 and the headlights are the delay module, headlight switch, beam selector, and those 2 fuses.
P Patriotsix NAXJA Forum User Location Jacksonville MC / Demorest GA Dec 19, 2016 #3 I'll check in the morning
J jhensley87 NAXJA Forum User Location Houston, TX Dec 20, 2016 #4 Had the same issue in a 96. The issue was in the turn signal assembly on the steering column.
