because you have to remove everything above the tube and then rewend what you need ontop of the truss, so where the truss meets the completely diff contour of the axle tube where the vac disco cast piece is, it wont fit right. I dont see why you couldnt clearance teh truss to work. but you would need to use a block off plate and prolly perm attach it (bolt it well and seal it good) and attach that also to teh truss.
