CollinM said:
Well, I've just heard the ballast resistor controls the vibes and noise the fuel pump makes and I have noise and vibrations coming from back there. I just replaced my 02 sensor last winter but I suppose it could be fouled, is there a way to test that? The other thing I wondered is how do I check for distributor play? I just replaced my cap and rotor also but I've never checked the shaft. Thanks a lot for the suggestions 8Mud.
Try wiggling the shaft from side to side, when the shaft wiggles about the same distance as the clearance from the rotor end and the cap lugs, your getting close to catastrophy. Rotor wiggling around in there, can´t be a good thing. It will move up and down a bit (never seeme to hurt much) and the gears do get worn and make a brrr sound.
The only time I can really hear my fuel pump, is when I turn the key to the run position and let it sit for a few seconds, before I start. I do it from habit, it seems to make the starts faster. It will run for a few seconds, then shut off (or get really quiet).
Í´m not a ballast resisitor expert, but have looked at mine a little, did an ohm test, but don´t remember the results off hand, a guess would say it´s pretty close to one ohm, with the wires diconnected and the resisitor cold. I have a jumper wire with a couple of spade connector tied around the wires, right next to the resistor and another near tied next to the connector for the thermo switch for the aux fan (nothing to do with this thread, but they are next to each other kind of).
Do remember checking voltage on a couple of occasions, seem to remember it being near 9-10 volts on the pump end of the resisitor.
Had one ballast resistor that got splashed with water and the back blew off, kind of like putting a hot glass in cold water. But it still worked, replaced it anyway, they are cheap, if you buy the generic ones.
Had an 87, that never had a ballast resistor, never noticed any pump noise, but maybe I was just used to it.
The ballast resistor was put in there to lower the voltage, when the motor was running and the resistor is bypassed during start and pump gets gets full battery voltage (or whatever is left over, after the starter gets it´s share).
Guess a ballast resistor could short across the windings and the pump could get too much voltage while while the motor was running, causing noise. A simple volt test should tell.
Lets get creative, get somebody to crawl around in the back and hold his ear to different spots and see where it´s loudest. I do that all the time with my son. Could be a CAT, a muffler, or something else.
I had a rusted piece of something in a muffler, that made kind of a Brrr, I kind of liked it, made my XJ sound kind of like a Ferrari.
If you just replaced the rotor, make sure it´s down all the way, they go on the shaft hard sometimes. I usually put a VERY lite, coat of grease on the shaft. I´ve had the shaft get a coat of rust on it and the rotor went on hard, a very lite buffing with a 3 M pad and then blowing the rust dust out of the distributor cured that.
