Natesgtojudge
- Chicago
'98 XJ 198k miles 4.0/auto/242
Out of the blue, while driving, what started as a whine began happening. This lasted for about 5 or 6 miles and seemed to only happen on deceleration. When applying the throttle/accelerating the noise seemed to disappear completely and all was normal. After those 5 or 6 miles it was as if I lost all power to the rear wheels. Engine revved, but nothing happened. Coasted into a parking lot and realized when I went to push the thing out of the way and into a parking space that even in park the Jeep would still roll freely. Messed around with the transfer case shifter a bit and discovered in 4wd high the noise went away and I was able to get the thing home. When I went under there I discovered the transfer case linkage was in bad shape, as I've read is common. Rusty, missing bushing causing a lot of play, etc. I have removed the stock linkage, manually put the transfer case into 2wd via the lever on the transfer case itself, and changed the transfer case fluid. The fluid was low and dark. Who knows when it was last changed. All seemed fine and I attributed the initial issue to the rusty linkage and/or low fluid in the XC. Went for a test drive in the neighborhood, staying close just in case. Made it roughly 2 miles before the noise started again, this time louder and immediately lost all power to the rear wheels. Again went under there and manually put it into 4wd and made it home, which is where things stand now.
I'm fairly mechanically inclined, but this is my first 4x4 vehicle as well as Jeep so I'm at a bit of a loss now as far as where to go to diagnose this issue and get it back to daily driver duty. Owned it for just over 2 years now and put 27k miles on it up to this point and she had been dead nuts reliable up until this.
