Which way do the RE LCA's go on?
Lowers go with the spherical joint at the axle, rubber bushing at the body. Grease fitting goes up (keeps it protected) and turn it so that it's not parallel with the arm.
IIRC, on the uppers, I put the grease fitting on top. I think there's an interference on the bottom.
Hey Kejtar
I don't know if you're done with your install yet. Just wondered what lengths you ended up with for UCA's and LCA's, and how you came up with them.
Thanks,
T
LCA's are fixed.... I think they are 16" and UCA's I set to 15.5" per recommendation that I got from RCP... and now it's getting aligned :D but I did run it on he freeway and got it all the way up to 80mph and it felt good.
