dudeinanxj
- Georgetown, KY
I have a Cobra 25LTD Classic mounted there with no issues at all.aci4369 said:I have mounted CB's on both sides of the shifter. The one on the passenger side is just like the others that have been posted. If you push the seat all the way up before installing it you will be fine. My last CB was large and fit fine. Here are some pics of the one that installed on the Driver's side. It was a smaller CB and I never had any problems with it hitting my legs. Although you can see that it is close, and I don't think a bigger CB would have fit. I am 6' 01" and ride with the seat all the way back, just for reference.
aci4369 said:
Peregrine said:Have ever seen anyone mount a small CB in place of the ashtray on a pre-97 XJ? The ashtray cover on my 92' just broke and won't stay closed...haven't gotten into it deep enough, but thought that would be a good placement if it will work. Any ideas on that one?
smccollamjr said:Here's mine:
jwtrapper said:![]()
Here is a picture of my overhead console on the bench. I like having the cb right there. Its easy to hear and easy to reach and its out of the way.
TomMcD said:Here's what it looks like with out the CB in place.
--Tom
TomMcD said:I thought about blocking off the vent in the dash and mounting it there but since I didn't need the ashtray and it was half hanging down anyway I didn't see the point of doing the extra work.
--Tom
AnzaJeep said:Any more pics or details on this. I have the same radio and overhead console and have been thinking about this option. What I'd really like to do is mount it the other direction and insert it into the plastic area that you have your switches located, cut the portion of the sunglass holder so that it is only a door, drill speaker holes in the plastic so I can hear, and then just open the sunglass door and plug in the mic when I want to use it. There is plenty of room for my unit, but the problem is there is a circuit board that is located there; what is it and what is it for? Can I simply relocate it further back?
