Wheel Cylinder Problem
lumberxj89
ventura, ca
Replaced the calipers/master cylinder on my sons '85 Pontiac Sunbird. Right front caliper wont release, causing the rotor to heat up. Any suggestions?
Check the caliper pins/bolts and make sure they are greased up. Also check to see if there is any defect that could cause the pads to hang up (may or may not be aplicable).
HTH
