Wheel adapters 5 on 4.5 to 5 on 5.5 (4)
Big Red
Roscoe, IL 61073
1 pair (aluminum spidertrax) set has lug nuts others set doesn't:
These 1.25" thick, 5 on 4.5" to 5 on 5.5", 6061T6 aluminum adapters now make it possible to change your wheel bolt circle! Simply install on an axle with a 4.5" bolt circle and this adapter will convert the axle to a 5.5" bolt circle. Each kit comes with 2 wheel adapters, 10 standard wheel studs (pre-installed), 10 lug nuts. The wheel adapters are anodized in dark blue, which is a double anodizing process for twice the corrosion resistance. Proudly made in the USA.
Each set sells for $100/pair normally, plus tax and shipping. I take paypal.
I will ship both sets for $150 in Cont. U.S.
(815) 222-9409 or [email protected]
thanks :compwork:
