- bourbonnais IL
oatmeal stout, not too bad for a Mr beer kit!!!
Noooooooooooooooo!!
I use Beersmith2 also. Wish there was an Android version available though.![]()
Now there's a good idea. You already know that tubing is suspect, and using it for mashing will drop the temperature extremes by 40 degrees F.
True... you'll want something a little warmer than your mashout.
I think I'm going to build a manual direct fired RIMS when I put together my brew sculpture, with an eye towards possibly adding a controller.
Scorching the wort in the bottom of the mash tun in a direct fired RIMS is a major concern.
One of the things that's concerned me about plate chillers (okay, any chiller where the wort flows through) is keeping it clean. I've heard about folks who pull the gaskets out of the connections and throw their plate chillers in the oven on a clean cycle.
John Blichmann is a bit of a character. For the most part, everything he sells is overengineered and overbuilt. Wish I could afford it.
Triple decoction mashes, you pansies. Come brew by hand with us Czech kids.![]()
I'm still thinking, but it's going to be a 3 station single tier, aka Brutus 10 style. 6 feet long, stations on probably 24" centers, 2x2x0.120" T304 stainless, with 15" or 16" openings for burners, and mounted on 2"x6" wheels. Top surface to be probably 20-24" from the ground, with mountings for a couple of March pumps on the lower level. I'll probably get the basic sculpture welded together this summer, not sure when I'll be able to finish outfitting it. Oh, and 3 burners. I've got a Bayou Classic SG14 burner that seems to work quite well, much more efficient than the usual turkey fryer burner and rather controllable. One of my goals is to be able to hose this thing down with a pressure washer (yes, that means the March pumps will be removable,) besides, I just like stainless for this sort of thing.dig.
where are you at with your stuff?
did you get started on a concept/design/build?
still waiting for less limited to get his zhit together....
i gave him a good head start....he's burning daylight.
I wanna see what a guy that makes awesome extract can do at the all grain level.
I'd like to see him hand over his NB kit woobie too.
tell him i said so.
i do double d with bohemian lagers.....
I *may* do one tomorrow with my chicago lager.
doing a 15gal tomorrow and doing a 15 gal beezil-kona brew on sunday with the latest intelligence gathered from the kona brewmaster himself.
I'm 81-percent sure they changed their hop schedule during the somewhat recent hop shortage...
lesslimited's buddy got some awesome insider info i want to put to the test.
