What size bore is a normal OEM throttle body?
90xj06 said:
how would you go about boring it. and how big. not that i will ever do it but if i wanted to.
I took mine to work,chucked it up in the lathe and bored it out.only took the taper out.Made a spacer too,matched it to the gasket size.
Wayne
It can be done with an electric drill, too, as done in a mod somewhere on the internet. I saved the page but the link is gone.
Buying another online is also possible - your core body can be shipped after to reduce the price and keep you running. Turbo city is mentioned on the page.
The mod is performed under the throttle blade, removing the taper with a drum sander in an appropriate size. Some disassembly is required. Gojeep has a writeup on his website , too.
No, I don't know why I haven't done it yet . . .
