What exactly could be limiting my flex?
BUCKYXJ
Tulsa, OK
Ok I have good flex but want more.
What all limits it in the front?
I have tera adj. lowers stock uppers and tera 3" coils with 2" spacers and OME long travel shocks. everything else is stock minus no sway bar.
DIG IT!
I have $200 to spend on just more flex what should I get?
This is a 32 degree ramp.
stock uppers could help limit it, are you sure thats not full travel on the shocks?
Have you trimmed the shock mounts on the front axle? The control arms usually catch on those as the axle drops.
-Brian
DIG IT!
Shocks and trackbar are ususally the biggies if the CAs arent hitting the coil seat. Rusty's or RE trackbar brackets allow for an infinte swing copared to a heim or a TRE. Disconnect your shocks and then ride the ramp.
at 5.5" my stock track bar greatly limits my flex. the track bar hits the axle mount when the pass side droops. you might want to invest in a HD track bar.
dig it
matthew
Got any closeup pics of your setup?
Take that $200 bucks, buy some tubing, Poly bushing and fab your own Long Arms.
I Dont dig it! :)
The rusty's TB will also bottom out on the axle mount, my buddies is redrilled a bit lower and to the driver's side to help with this. and oh yeah, cut more
