old_man
- Loveland, Colorado
OK, here is the required, what do you have to do before ColoradoFest thread. Post up.
install pass seat,shocks,shock mounts,new upper and lower arms,pull t case and install seals studs and cable shifter mount,front yoke,drive shafts,new diff covers,rear wheel spacers ,all fluids, fab and install rock rails,front u joints and alloys then see if it runs drives. thats just what I can remember who wants to come help on saturday??????
Normally I wouldn't post in a thread like this so people won't realize how slow I am... but oddly enough I feel like I'm running out of things that need to get done.
I need to try and get the front brake lines to stop rubbing on everything. Give the interior a good cleaning. Check all the bolts/nuts I've messed with recently. Maybe I'll fab up new front swaybar mounts if I feel like it. :shocked:
Put tires on the Jeep and charge batteries for the planes.![]()
down to reinstall tcase for the umteenth time, finish seat belts,cut off and remount upper control arm mount on front axle,adjust steering ,mount spare ,mount gas tank skidslap some paint on some stuff.... then on Tricias I gotta drill for new steering replace track bar end,and finish bolting down the cage mount her spareinstall pass seat,shocks,shock mounts,new upper and lower arms,pull t case and install seals studs and cable shifter mount,front yoke,drive shafts,new diff covers,rear wheel spacers ,all fluids, fab and install rock rails,front u joints and alloys then see if it runs drives. thats just what I can remember who wants to come help on saturday??????
Get rid of t-case drop.
Put on new HD tranny crossmember.
Weld on frame stiffners
Weld on rock sliders
Fix rear brake line issue
Put in newer seats
Put on new Trac Bar
New Tie Rod Ends
Oil Change
Hood Vents
Front Axle Seals
