I am upgrading my 99 XJ from 3 inches to 6 inches. The SYE is in the near future. My question is what degree shim should I run to help out with the angles? Appreciate it.
I know you have probably read this elsewhere already but... I recommend thand you measure it first and get what you need. You probably can get shims locally, they are easy to install, and then you will know you have everything correct.
-Brian
