weld on JKS mini skids
You bet! Come over, I will have you finished in less then 30 minutes!
Also to everyone, if you don't have Mini skids get some, they are cheep can be put on fast, but can save you very big headakes later.
Just threw some on mine the other day! One of my first welding projects as well... Should have done it before I bent my LCA bracket though...
I have seen more then a few rip off and they always seem to find a rock or two to get bent on.
Also if you are going to weld on the mini skids you might also want to put a bead on the inside of the LCA mount, they as are only welded on the outside.
Also if you don't pull the LCA off you might want to put a cool wet rag around it to help keep your LCA bushing from over heating and melting . . .
I think we met this past winter, right? Anyways we'll have the welder out and running on the weekend of July 24/25th, we'll be doing some repairs on a bud's XJ. We can get those welded on for you in no time. Like everyone else, I highly recommend them.
Let me know.
Dave
thanks for all the offers everyone. Chris lives down the road from me so I will try to get together with him. If that does not work out I will take you up on your offer Dave.
And yeah we met at a snow run this past winter with NAXJA on mormon and the winter before I met you, mark and that whole crew.
Chris, I'll give you a call.
Josh
chris if youre doing his can you do mine at the same time?
ill throw in free parts and cash for any wire/rod or gas you use....
Let me know.
Dave
Just noticed this is the weekend of SierraFest. I will be up there for the event. You should try to come up for at least the weekend.
Thanks anyway Dave.
id be down to join up for this mini skid burnout.
ill throw down whatever i need to throw down
