Weird idle surge.
streetxj
My 2000 jeep cherokee has been doing something weird, yet the Check engine light is not on. It doesn't even do it all the time. When I'm slowing down the idle seems to hover at a higher rpm then normal. At a near stop its suppose to dip below 1000 rpms. When the problem occurs, the idle stays at or slightly above 1000 rpms and when I put the shifter into park, the rpm climbs to 1,200 rpms and drops to 1000 rpms and hovers to 1200 again. This only occurs when the a/c is on. I turn it off and crank it back on and it goes away. Can it be the TPS or one of the sensors located at the throttle body? I have maf and contact cleaner, maybe I just need to clean the sensors?
The Idle Air Control (IAC) is mounted on the back of the throttle body. The valve controls the idle speed of the engine by controlling the amount of air flowing through the air control passage. It consists of a stepper motor that moves a pintle shaped plunger in and out of the air control passage. When the valve plunger is moved in, the air control passage flows more air which raises the idle speed. When the valve plunger is moved out, the air control passage flows less air which lowers the idle speed. Over time and miles, the IAC can get carboned up which can have an adverse affect on idle quality. Cleaning the IAC may restore proper function and is an easy procedure to perform and good preventive maintenance so it is never a bad idea.
CLEANING THE JEEP 4.0 IDLE AIR CONTROL
Remove the air filter cover, associated hoses and the rubber boot that goes from the air filter cover to the throttle body. Remove the IAC with a torx driver (2 bolts; one can be kind of hard to get to)
“Gently” wiggle out the IAC from the throttle body. Gasket on the IAC can be re-used if it is not damaged
Clean the IAC with a spray can of throttle body cleaner; inexpensive and available at any place that sells auto parts. Throttle body cleaner is recommended rather than carburetor cleaner as it is less harsh, safe for throttle body coatings and is best for this task. Use cleaner, a rag and a toothbrush and or Q-Tips. Be gentle; don’t twist or pull on the pintle that protrudes from the IAC as it is fragile and you could damage it.
Thoroughly spray clean and flush where the IAC seats in the throttle body with the same spray cleaner
It is also a good idea to clean the entire throttle body itself, the butterfly valve inside of the throttle body and all associated linkage as long as you have things disassembled
Reinstall IAC and check idle quality
Thanks! :)
Could be sticky IAC, could be a vacuum leak, could be TPS. I bet you know somebody with a live data capable scan tool to check the TPS, or you could backprobe it with a voltmeter and look for bad spots.
Garbage in, garbage out: a wacky sensor (input) will cause EFI operation (output) to go south in a hurry.
Don't forget to check the MAP sensor too. I had the same problem on my 99 with the defrost and e fan kicking in. New map sensor fixed it for me. Haven't really tried the a/c yet.
I'll clean the IAC, and check out the other sensors. If it was the TPS, will it do it all the time? I'll check it out this weekend. Thanks for all of your help! :thumbup:
