Talyn
- Radford, Communistwealth of Virginia
Anyone one have any experience with this? Besides Snow Performance any other good companies?
I can give you a good source for the water/methanol to be injected.
I used it on a motorhome in the 70's. It helped the power, especially pulling mountain passes here in Colorado. I even played with mixing some nitrous in.![]()
Windshield washing fluid works quite well. Read the ingredients on the label.
Well, Once upon a time... Just after Dirt was invented and before rocks, I worked on Aircraft with relatively large (3,550cuin) engines on them.
We used water/methanol injection on them. The engines were a two speed internal supercharger equipped two row radial engine that was fuel and water/methanol injected and had three Power Recover Turbines. THe PRTs were the turbine half of a turbocharger that had the ouput shaft connected directly to the crankshaft via a viscous coupling. At maximum BMEP (brake mean effective pressure) each one delivered 150hp to the crank. This engine, the R3350 Compound, developed more power than the 4 row R4360 engine.
Yes, that is an 28 cylinder (4 rows of 7 as all radial engines have an odd rather than an even number of cylinders) engine with 4,360 cubic inches of displacement. Think really big here...
Not bad for 1930s technology which is just how far back water/methanol injection goes. The thing is (as I understand it) the water/methanol will flash into steam in the cylinder vastly increasing the cylinder pressure.
More cylinder pressure = more Hp. As a plus the steam mitigates detonation. EGT cooling is a by product.
On my list of to-do things as one just can not have too much power on tap.
When it comes to an internal combustion engine. Everything has been done already. Fuel injection started in the 1920s for Diesels and by 1952, gasoline engines were factory injected. I believe that Hilborn did a mechanical injection setup for racing in the 1940s but could be off base there.
Point is, this technology is well proven and it works like a charm.
AND, as a side benefit, your combustion chambers will stay clean. No carbon build up at all.
Think Steam Cleaned as a matter of fact...
What do you suppose would happen if I ran my 4 stroke model aircraft engine fuel? It contains 15% of 99.7% pure nitromethane in a castor oil base. Not much in the way of cooling...
