water in passenger foot well
Berrill
Cape Town
Last night I left my jeep out in the rain, this morning the passenger carpets were sopping wet.
The windows and doors were closed.
It seems as if the water has entered from somewhere under the dash.
Can anyone recommend where I should start, maybe there is an area in the engine compartment that is blocked with tree leaves ECT?
The jeep was parked on a steep sloping drive way. The back of the jeep was much lower than the front.
Any ideas where I should start looking.
Thanks Antony.
I have the same problem, read all the threads, looked everywhere. I HIGHLY suggest getting your cordless and a 1/4 drill bit, and popping a few holes in that floor RIGHT NOW. You can still search for your leak all you like, but a least you wont have Lake Cherokee every morning. You may save your carpets, your floor pan, and your sanity in the meantime...cheers
- TJ
make sure the A/C drain isn't clogged or kinked....I went swimming last summer when mine got plugged
