Warn HS9500i Winch with receiver mounting plate and cradle
XJEEPER
NAXJA Member # 13
Wasatch Range
HS stands for High Speed, the 9500 stands for rated line pull weight. The i means integrated solenoid.
With a 4.6 hp motor and 500lbs more recovery capability over the XD9(i) series, the HS95(i) would be perfect for almost any vehicle recovery scenario. The HS95(i) boasts a faster line speed than the XD9(i) platform. With a line speed comparable to the legendary M8274-50, along with 1500lbs of extra grunt, and its reconfigured the drive train to a planetary gearing to improve speed and efficiency, this 86 lb. winch is simply the best bolt-on self-recovery improvement for the money.
Complete with remote controller with 12' cord, roller fairlead, winch cradle/receiver mount and YJ-TJ receiver mount plate, this setup give you the flexibilty of using it for front or rear vehicle recovery positions. All controls work and and cable is in good condition, unit is ready to bolt-on. Decals near lever are peeling, but new Warn decals are included.
$495.00 obo
Jeff
Cell 801-390-nine zero one eight
http://www.ksl.com/index.php?nid=218...383799&cat=556
No Problem... Wish you would have waited until the end of November to post this....
:anon:I just dont have the funds right now...
