WANTED - Stock springs
Boatwrench
Petaluma, CA
Just like it says, need stock springs to roll junk out of garage and off to pick-n-pull.
Oh and cheap too.
picknpull doesnt care for springs . i drag jeeps out of teh garage all the time on just bare frame rails(with sand on the ground and 4x4x4s under the frame rails ) with the axles in the jeep (dana 35/lp30s) technically it has axles still, and they never seem to care. just call for a flat bed and explain whats up. if youre concerned about dragging a bad tranny or engine you can throush some plywood under it. they wont pay you any extra for coils/leaves on the vehicle. just an idea.
true that!!
Is this just to get the Jeep out for PnP? If so I also have a suggestion (that worked). Lower the Jeep onto Pallets, then they will drag it up on the truck. Mine had NOTHING under it :-) It worked great.
Yes just to get the hulk out of the garage. The floor is epoxied so I just want to be able to roll it out and not mar the surface.
I also have stock coils. No leaves though- Free
Mark-
I could actually use a stock rear pack if you have them still and IF Boatwrench does not need them. DD my rig and need to build a bastard pack. I'll put the old set on Karma after done or you can have them back.
