I have a mild 1.75" spacer lift on my 92 xj and it feel squirrley and I already replaced the ball joints, tie rod ends, track bar, steering box & pump, and checked for loose nuts & bolts. The steering dampner appears good as well.
I think my castor is slightly off and I can not fit any more castor shims behind the stock LCA's. The only other thing I think it may be is the 8.25 C-clip axles seem to move in and out of the axle tubes a bit but from what I read this is not uncommon?
