Want feedback on 4 links systems.
Slonopotam
NAXJA Member #1358
San Jose
Hi,
I do not see a lot of feedback on 4 link suspensions. I am specifically interested in synergy, full traction and froehlich.
http://www.synergysuspension.com/Sy...ront-4-Link-Long-Arm-Kit-Bolt-On-p-25563.html
http://full-traction.com/detail.php?MODELID=4&MAKEID=1&TYPEID=1&PRODUCTID=98&NOTES=9,10
http://froehlichsuspension.3dcartstores.com/XJ-4-Link-Upgrade_p_11.html
The usage will be mostly highway, infrequent off-road trips to rubicon/deer valley.
I saw somewhere that a man switched full-traction for a tnt y-links. Why would somebody do that ?
About synergy and full traction - do they work with some belly pan/reinforced crossmember?
Somebody mentioned that a modification had to be done to fit synergy and tnt bellypan together. As a result, is bellypan between the body and arms mounts or is it the other way around ?
Mainly ground clearance,also simplicity!
Based upon my direct experience...
If I had it to do over I would go with the Full-Traction. I did not go that way to begin with as FT, at the time, did not sell just the arms and mounts. Now they do. I had a lift and just needed the CAs and mounts...
Full-Traction is an established, professional, company and it is hard to beat the product. I am running FT springs in my lift.
I'm in the process of getting my Serious Offroad stuff installed...it's really nice and the price was great. Have you looked at it?
FrankZ makes a radius arm setup that it second to none. At the last M&G, we talked about a 4 link. BTW, I will be replacing my long armss with some of Frank's this spring... Good guy, great products and he stands behind them 100%.
