This JP is a daily driver for me. I drive 18 miles one way to work and generally about a 40 mile loop daily on the weekend. The off road park is 75 miles away if I head up there. The farm is about 35 miles one way and I’ll head over there a couple times a week as well.
Vehicle:
1991 Cherokee 4.0.
Problem:
Intermittent crank, no start. High idle and rough idle until warm. Occasionally dies while running/driving.
Things I’ve checked/replaced:
CPS is new, TPS is new, IAC is new, throttle body is new and cleaned, vacuum system is tested and good, ASD relay replaced, both temp sensors replaced, new plugs .040" Champion copper, wires, coil, 12V to coil, distributor is a few months old and looks brand new no damage or water signs, O2 sensor is new,
Background:
Running trails at the off road park one day, all day, raining, hot. Parked and went to dinner. 90 minutes after, JP would turn over but not fire and start. Left it until morning. Next morning checked for spark, none. Put on another coil (factory), fired right up and ran perfect for one month. I thought it had a bad coil/coil died.
Got gas. Went inside and bought some sweet tea, Pure Leaf brand. Not the extra sweet, that’s way too much. Back out to the JP and turns over, no fire and start. Swap another coil on (MSD), fires up and runs like a champ. Now I’m wondering why it’s burning up coils.
Drove home. Parked. Next morning turned it around in the yard to pull into the shop and troubleshoot and it dies just outside the shop. Died while driving. First time for this.
So I’m wondering why it’s burning up coils. I pull the coil plug and check for crazy voltage: 12V input. I unplug the battery and ground pos to neg for 30 seconds and leave disconnected for 10 minutes. Still no fire. I swap another coil on, fires right up and purrs.
It’s due for a new set of plug wires and plugs at this point so I pull the old. Plug wires are ohm’d at 43-45K. Champion plugs are at .045" gap. Swap out for MSD plug wires and standard Champion copper plugs at .040" gap. MSD plug wires ohm at 3k. No fire from coil.
On a weird hunch because I am thoroughly enjoying the pain so far, I grab a coil that has previously failed and install it. Fires right up and runs like a champ. Head smacking ensues. Cycle through all previously failed coils and they all work fine.
JP runs about 6 weeks through multiple off road park trips of much hard core banging and 99+ degree 100% humidity weekends and runs like a scalded ape.
I get off work one morning (graveyard) and JP turns over, no start. By now I have already relocated the coil to the fire wall and have a spare coil bolted beside it. So I swap the coil plug and the distributor wire to the other coil. Fires up and runs 10 miles.
Dies going through one of the smallest towns in existence, but fortunately it has a post office. Unfortunately for the people that get their mail there, the PO is probably only open for 7 minutes at some crazy hour that no one actually is moving around. I pull in the parking lot and disconnect the coil that is currently in use, wait 10 minutes, reconnect it. No start. Disconnect the coil, disconnect the battery, wait 10 minutes, reconnect. No start. Swap to the initially running coil. Fires up and runs fine.
At home I swap it back to the last failed coil and it continues to run fine. At this point, my high idle issues at cold start are getting worse, so I work on that. Vacuum test everything under the hood. No leaks. Pull throttle body, clean (was clean). TB gasket is new and shows no signs of leaks. Pull IAC and TPS and clean out. Connect IAC and turn on key, plunger moves in as it should. Put everything back on and it fires up like factory, no high idle, perfect.
Until I back out of the shop and as soon as I apply a load it starts coughing and missing and sputtering and will only move if I give it ¾ throttle and then it goes barely. I am thinking I killed the dang TPS so I swap a back-up (new in box) and there is no change. JP only starts with accelerator to the floor at this point and runs like it’s missing with zero power. I pull the battery cables and let it sit for an hour. No change. On a stupid hunch I swap to the other coil, fires up and runs like a champ.
That’s where I am. I think the next step is road flare and a gallon of gas. I’m up for anything at this point. I’m sure I’ve left out something somewhere. Guys, pull my head out of this hole I’ve dug and give me some direction. Thanks up front!
Steve
Vehicle:
1991 Cherokee 4.0.
Problem:
Background:
Steve
