Various Parts
pjanda1
Boulder, CO
Header panel for an '84-96 Cherokee? one crack at the bottom, but solid with good screw holes: $20
Clutch Fan, good and tight, forgot to take a pic: $20
Brake rotors, great shape, for a '99 and later D30, these might also fit TJs from those years: $20
CB Antenna that will fit a rain gutter on an XJ, adjustable, maybe it would fit others? $10
Stock length shackles, useable, not great: $10
Stock yoke to the driveshaft for a d30 or d44: $5
Stock coil spring isolators: $5
Door lock actuator, from a '96, maybe drivers? Probably works? Free!
d30 long side and short side inner shafts: Free!
I'm looking for (in trade, I can put in cash if need be): a front driveshaft for auto/231 with GOOD u-joints, good tail lights or anything but the headlights for a 97+, GOOD tan late model seats.
The free shafts are gone.
I do have a set of D30 axle shafts with bad u joints but good unit bearings. I'd take $60 for them!
Paul
Pictures might help sell these, much depends on the U-Joint that is standard to the shaft.
