Vacuum Disconect for Dana 30
89xjchick
Is there a way to disconnect only the passenger side for periodic turns. My front end is welded and it is difficult to make turns. I am hoping someone knows which vacuum cable engages the passenger side so that I will have "3 wheel" drive when disconnected. Are there any known hacks? Tried searching but got no results.
Thanks!
Heather
The easiest way is to remove the vacuum motor and check it
I think with a fingertip over the ports, you'd feel suction on one of those ports and pressure on another when you manually slide the shift fork from right (unlocked-3WD) to left (locked-4WD) and the opposite returning it to unlocked.
once that is determined, plumb a source of vacuum up to it through a switch (like the old FS Jeeps with Quadra Trac?) or something like a motorcycle fuel tap that had A+B ports
Or just spend a little more on a Posi-Lock, which converts from vacuum to in-cab cable...$180 from Rusty's or lots of other vendors...
HTH
Thanks for the help! Yep, know about the Posi-Lock option...just wanted to try and hack it ourselves instead and save some $$.
-Heather
