Using 2WD AX15 X-member and mount with 4WD AX15
1987Comanche
NC
I'm gathering parts to convert my '92 MJ 4.0HO AX-15 from 2WD to 4WD. I found a 4WD AX-15 out of a '94 XJ (P/N 52108047) but I have no brackets. I have a line on the front axle, transfer case, front driveshaft, linkage, and rear slip yoke out of a '96. The cross-member and trans mount, however, are already gone.
Looking through the Mopar parts manual it looks like the AX-15 only used one x-member and one trans to x-member bracket, regardless of 2WD or 4WD:
M/T X-member: 52003929
M/T bracket: 52003927
Can anyone verify the cross-members and brackets for the ax-15 are the same? If so I can reuse the existing parts.
Anything else I'm forgetting? The only other thing on my list is to couple the '96 slip yoke to my rear driveshaft and have it cut down/rebalanced to fit.
They are the same, use your existing one.
